I think that some people have had reasonable success with a 'stealth' neck pickup on Esquire's by putting a slight Gibson style back angle on the neck join by routing the neck pocket at an angle. By doing this the strings pass low enough over the scratchplate where the neck pickup would be for it to work but still hit the bridge t the usual distance off of the body. Don't know if it would work on the mid pickup though
IIRC there's been a few guitars made with "hidden" pups. I'm sure Jackson have done some, but with 'buckers so maybe it would be possible with a higher output, over a "vintage" output pup.
The point here wasn't to use the doubled mags to 'jump' the magnetic flux further, for example past a scratchplate, but to use the side effect of a larger coil aperture to boost bass and mids.
OK so it'll still be visible, but from a distance it will have the look of a Tele configuration. Tis a compromise, of course, but still..
