I'm pretty good at it because of this and I can do it without thinking- it is my default.
The rest of the time I sweep/play economy.
I'm decent at it but I need to concentrate and I need to keep working on it.
I can't alternate pick very well at all, but I don't really need it.
You get good at whatever you work on.
The way i am approachig this is either alternate for that part or pick and finger...
I think hybrid and legato are great iff you take ideas that that make them styles work as in maybe exercises...but more difficult in lines that were never thought of with them in mind ...hope it makes sense what im trying today
I would probably alternate picking.
If it is a 3 note chromatic line then I either pick hammer pick or pick hammer, hammer.
When I say I'm not good at alternate- I'm fine with runs of 5-10 notes- I just don't practice doing it all the time- I couldn't do the Petrucci thing where pretty much everything is picked.
The last 6 months or so I've really worked on economy picking and I think it's made a big improvement in tone and the fluidity of my picking hand movement.
As in maybe Holdsworth for Legato
Maybe Mclauglin for alternate picking
Tm Miller for Hybrid
Gambale for economy
These players dont really cross over doing all the syles seamlessy...although they dont need to cos thats what makes there style
The reason i ask is every one of the above ways has certain limitations apart from probably alternate cos you dont have to rely on left hand patterns...just something i have been thinking and iff all styles could be mixed at a high level to intergrate all of the above ..
I think most players do this but in a limited way..
A bit of all, apart from economy picking which I don't use with the exception of an occasional double downstroke when ascending strings.
I'd love to be able to play proper legato with all hammer on's, where you don't need a pick at all, mainly because again, it's useful on an acoustic. It seems to me that it's much more a kind of playing the piano technique. I've been practicing it a bit and I can see the muscle memory start to change, but it's all a bit boring to be honest and I'm not sure I can be bothered to learn it as much as like to as it takes a long time to change. Also it's hard to be inspired by, as I've always favoured bluesy stuff as opposed to exacting note volume and dynamics in passages where as proper legato is about exacting volume and dynamics, more so than alternate picking where you have much more control over it, but it is the mark of a capable player and believe everyone should be able to do it, although only a rare few of us will be arsed.
Naturally for fast electric stuff it's pull offs and hammer ons and some picking, sometimes they just sound better and more dynamic and out of phase than straight picking alone, although sometimes vice versa, although these days I sometimes find myself picking everything if it's made up fast stuff, especially of I'm drunk on a strat. I wouldn't say the tone is necessarily any better although it's good I suppose that I can do it subconsciously vaguely, but even on acoustic, on long runs, sometimes the softer pull off notes do sound better.
What I'm really trying to work on is finger picking and independence from thumb and fingers which I haven't practiced since doing classical as a kiddie and even then I never ever got it down as far as improvisation went and only did it on rehearsed pieces for grades which I practiced slow to figure out where the bassline was and then brought up to speed. For me, this is where the guitar comes into it's own. Must be middle age.
Which reminds me, I should really work on some legato and economy picking as I quite like the fluid sound it gives.
Twisted Imaginings - A Horror And Gore Themed Blog http://bit.ly/2DF1NYi
If I'm on the same wavelength, I generally like to alternate between down and up where possible, but sometimes find its just down-strokes.
I use plectrum almost exclusively.
Hybrid is using a pick and one or more fingers.
Legato is using hammer-ons and pull offs (with or without some picked notes).
Economy is using consecutive down or up strokes when crossing to the next string. so for a 3 note per string scale going from low to high the pick would go down, up, down, down, up, down, down etc.
