The guitar may not sound at it's best with 11's so I'd up to 12's.
Re-stones aren't that difficult to do - I use a 'diamond' stone or leveling.
worth checking if it is a high fret with a rocker and taking some steps to fix it. Then you can set the relief to your preference, not just to hide an issue
Instagram
This has the effect of the f/board having a SLIGHTLY bigger radius under those two strings - it's actually imperceptible.
In the middle of f/board it would be noticeably - string bends etc.
