So, what PA system do I want to buy? Basically want some nice sounding active tops for pub gigs that I can add a sub sub to for doing wedding stuff (offering the whole mp3 dj through our PA system too)
Singer owns one of those HK Lucas nano things that we use for our acoustic duo/trio gigs. Sounds great and is a doddle to setup. Loved the sound of pretty much every HK system that I've ever used.
Seen the HK premium pro stuff. Do you guys think that 2 of the 10" tops with the 210 sub would be sufficient? The main wedding venue that we'll be playing is pretty small tbh....think that it's 120/130 max capacity......we play there most Thursday's as back ground restaurant music using the HK nano thing and it's fine at about 1/4 volume!
Also seen qsc k10's but adding a sub would probably stretch the budget too far.
Thought's?
Two 10" tops and a 2x10" sub isn't much.
Really like the look of those yamaha dxr10's. Never used a Yamaha PA before.
With PA gear you certainly get what you pay for, I've had stuff like Alto and it really isn't a patch on RCF or high-end Yamaha. I would go for 2 10" or 12" tops and 2 15" subs. Our band (4 piece rock) uses 2 RCF 710;s over 2 DB Sub-15D's and it sounds great for small - medium venues
Another one to consider is the RCF ART745-A. This isn't your normal active plastic box and has one of the best high frequency horn driver in that price class IMO. http://www.rcf.it/products/pro-speaker-systems/art-7-series/art-745-a
A pair of those over an ART 905 sub is very potent and portable. Price is creeping upwards up though... but you never know maybe second hand?
(I've got the RCF TT25A ii tops and they use the same horn as the ART 745-A and cost over twice as much)
With the sub, just get one good 15" for starters and really experiment with positioning in the room. It doesn't have to be directly beneath the top(s). Getting it up against a wall stage left or right can really increase output..
