if you do want to replace it no mods are required other than drilling some screw holes for the new tuners. New ones will drop right in as long as you get the correct size bushings. (Google will confirm what the correct size is.)
You may call me a luddite if you like, but I'd do the same as rico. Then you can sell the G-Force as "unused" and maybe get a bit more for it. I can't be bothered with something that needs charging, can fail (I've seen a couple, and it would be a right pain at a gig), feels so awful to use manually and adds unnecessary weight to the headstock.
If you like them I'd be inclined to make rico an offer so you at least have a spare. (Seriously.)
My band, Red For Dissent
Not sure what you mean. The GForce just gets the strings in tune and then switchs itself off. Its not always on, only on while the strings are being tuned.
You can then also choose whether to keep the Gibson string spacing or to make it slightly wider to better fit the neck width.
Will have to think on the nut replacement but i'm swinging towards a traditional nut.
But that raises another question: does it turn itself on when a string is out of tune, or is it manually tuned on and off by the player?
But that raises another questioin: is the system manually turned on and off by the player?
