Fret Buzz
Si_Si_ Frets: 384
Hi chaps,
is there an easy way to eliminate fret buzz on an acoustic? it's simple on most electrics but the acoustic seems be a tech job.
  • vizviz Frets: 10647
    It's fret buzz that gives acoustics that lovely acousticky sound.
  • VimFuegoVimFuego Frets: 15476
    have you identified where the buzz is coming from?
  • bertiebertie Frets: 13564
    bees
    heh, I tried one of them handmade, high end Yamaha acoustics once that had a loose brace. Sounded like a seriously fucked off wasp inside.
  • ESBlondeESBlonde Frets: 3576
    If the action has been dropped too much by shaving the bridge saddle then a new saddle is the only real answer. BUT check the truss rod adjustment and also look to see if the body has 'bellied up'. It might be a loose brace allowing the top to flex and cause the bridge section of the top to droop down.
    An eye along the face of the body (with a straight edge layed on too) will give you an idea. Get it too a good luthier for a proper appraisal.
    You can swap saddles and/or carefully adjust the truss rod without visiting a tech. Not a huge difference from an electric.
    Has it got worse over winter?
  • Si_Si_ Frets: 384
    It's a new guitar, so not really got any worse, but it's always been like this.. it's not really bad, just annoying..
    are there any speciifc frets/area that buzz more than others ?  -  is it a 'fret buzz'  type buzz, or could it be from elsewhere ?
  • Si_Si_ Frets: 384
    defo fret buzz,,
    area(s) ??   ie close to nut,  12th fret.  all over
    What did you buy it for then!?
    I think you should get it looked at because you're gonna end up going down a rabbit hole here. Might need a simple adjustment or a fret level, depends on how annoying it is to you. Tech should ask you about your playing style, if he doesn't - walk away.
  • Si_Si_ Frets: 384
    It was a Christmas present so I didn't get to play it before it was bought.  I'll probably pop it back to the store to be checked out.
    Ah right, let's hope they sort it for you.  :)
