A few punky areas in the spalting - flood with thin cyano?
Adam
i wouldn't expect it to need too much hardening, but you never know.
I have soaked the some really soft bits of maple with super thin CA, it soaked up loads. But then I needed to recarve a section and found it hadn't gone very deep at all
i wonder if plain old wood hardener would be worth a try.
Instagram
I have not used spalted maple before, but I have certainly used the beech that had some very soft areas - compressable with a fingernail easily. This when turning bowls for instance, or making boxes, I found that the cyano needed repeat applications, but worked well.
I also have no experience with wood hardener - what is it?
Cheers,
Adam
http://www.screwfix.com/p/ronseal-wet-rot-wood-hardener-clear-500ml/63540
That's the stuff I was wondering about. I used some for its intended purpose of repairing a window last year and it got me thinking
Instagram
Again, never having used the stuff, I wonder about it's suitability regarding a finish to be applied over it, going from the comments above.
Obviously, this is all moot if there are no punky areas to the spalting. It's probably worth doing a test piece anyway, if only for future reference.
Either way, a nice bit o' timber...
Adam
Beech arrived today but its a little damp looks like Parcel Farce left it out in the rain,it was shrink wrapped and bagged but areas at top/bottom and side had been pulled off (looks like someone was trying to have a nose at what it was)
Anyhows the bit of spalting's solid non punky and the area at the center of it 1/3 down 2nd pic is a bark incursion
Ive used that kind of Wood hardener on a burl top for a 6 string bass i built about 10 years back that was a little punky in places i just left it in a Wood hardener bath for a few days then let it dry and it finished it with danish oil & it came up fine
I'll try and grab a few wipe down pic's of this once i get this up the road,and a few more once its split/bookmatched
