Assorted woodworking machinery - Surrey
SporkySporky Frets: 28095
edited February 2017 in Misc £
Draper sliding compound mitre saw. 10" blade. Surface rust on the rails but runs very smoothly; I'm happy to clean this up and put some machine wax on. Excellent for laminate flooring and general DIY; you can do some better precision work if you're prepared to spend some time setting up. Around £150 new; £66 collection only. Pics tomorrow.
SOLD - Draper 16-speed floor-standing pillar drill. Upgraded with an Axminster arbor and keyless chuck and a nice extended table (15mm ply if I remember correctly) with sanding drum insert. Quiet and smooth. About £250 for a new one; £111 collected. If you don't want the ply table you can have an Axminster cross-clamp vice instead. Assuming you can lift the bastard thing. If you want both add £37. On the left here.
http://monkeyfx.co.uk/pictures/workshop/workshopmain.jpg
http://monkeyfx.co.uk/pictures/workshop/drill table insert removed.jpg
Axminster extractor. 63mm duct - and lots of it included. Works nicely for a tablesaw, drill, sanders, just not really up to a 10" planer/thicknesser. Note that it's a chip extractor, not a fine dust filter. Probably £200ish all-in new; yours including some spare collection bags and all the ducting parts for £93.49ish. You can have the plastic bin and RP cyclone lid too. In the middle here:
  • RolandRoland Frets: 8701
    What's the clearance on the drill, from centre to the stand?
  • SporkySporky Frets: 28095
    Dunno, but I can check. Enough to drill trem post holes and such, certainly.
    Also free with any purchase (otherwise £27.44 and a Chunky Kitkat) is a planer thicknessing jig. Aluminium box sides, holes for bench pups, PFTE slides and an aluminium sled and polycarbonate spacer (drilled for Bosch GMF 1400 CE but holes are easy to make).
    Picture while in construction:
    http://monkeyfx.co.uk/pictures/workshop/thicknessing jig.jpg
    @Roland - sorry it took a while, I've not been to the old workshop much. It's 170mm.
    Have still got the pillar drill and chip extractor?
    I have. :)
  • MtBMtB Frets: 922
    Hopefully not a numpty question, but does the drill work from a home single phase power supply?
    Yes. All of these will run off a normal socket.
    I can check exact power requirements tomorrow if you're interested, but they don't need anything unusual.
    Drill provisionally gone.
    Drill press and router thicknessing jig gone to the man not-in-a-hat.
    Chip extractor and chop saw still for sale. But for how long?
    Well, for a while, it turned out.
    Now £57 for the chopsaw, £87 for the chip extractor.
    Getting very close to house clearance time; chip extractor needs to go to a loving home or the scrapyard in the next couple of weeks. Cheeky offers considered (on the basis that you come and collect it and help take it off the wall and so on).
    Chopsaw also still available.
    What model is the chopsaw? I know someone near Guildford who might be interested.
    Dunno but I can check. It's a Draper one, 10" blade I think. Perfect for DIY, OK for light trade I'd say.
