Fender said "Treble and Bass eXpander", but they don't boost treble and bass at all - what they do is artificially strangle the tone over the lower half of the range, then progressively remove the strangle as you turn it up full to make you *think* it's opening up the tone, but in a way that somehow doesn't pass through 'good'.
They were designed for active guitars, where they actually work well. Why Fender decided to apply them to passive ones, I have no idea…
You can fix the problem very simply by removing the 82K 'strangle' resistor, which gives a normal tone control (albeit with the wrong cap value for a true vintage sound) from the detent down to zero, and a near no-load setting with it at 10. But a standard 250K pot with a .047 or .1 cap still sounds better and has a more natural sweep, to me.
