MODEL | Martin 000-18 Golden Era 1937 Sunburst |
CONSTRUCTION: | Mahogany Blocks/Dovetail Neck Joint |
BODY SIZE: | 000-14 Fret |
TOP: | Solid Adirondack Spruce |
ROSETTE: | Old Style 18 |
TOP BRACING PATTERN: | Standard ''X'' Scalloped (Golden Era Style) |
TOP BRACES: | Solid Adirondack Spruce 1/4'' |
BACK MATERIAL: | Solid Genuine Mahogany |
BACK PURFLING: | Solid Brazilian Rosewood Strip |
SIDE MATERIAL: | Solid Genuine Mahogany |
ENDPIECE: | Delmar Tortoise Color - Brown |
ENDPIECE INLAY: | none |
BINDING: | Tortoise Color - Brown |
TOP INLAY STYLE: | Multiple Black/White Boltaron |
SIDE INLAY: | none |
BACK INLAY: | none |
NECK MATERIAL: | Select Hardwood |
NECK SHAPE: | Modified V w/ 30s Style Heel |
NUT MATERIAL: | Bone |
HEADSTOCK: | Solid/Square Taper |
HEADPLATE: | Solid Brazilian Rosewood /Golden Era Style |
HEELCAP: | Solid Black Ebony |
FINGERBOARD MATERIAL: | Solid Black Ebony |
SCALE LENGTH: | 24.9'' |
# OF FRETS CLEAR: | 14 |
# OF FRETS TOTAL: | 20 |
FINGERBOARD WIDTH AT NUT: | 1-3/4'' |
FINGERBOARD WIDTH AT 12TH FRET: | 2-1/4'' |
FINGERBOARD POSITION INLAYS: | Old Style 18 |
FINGERBOARD BINDING: | none |
FINISH BACK & SIDES: | Polished Gloss |
FINISH TOP: | Polished Gloss w/ 1937 Sunburst |
FINISH NECK: | Satin |
BRIDGE MATERIAL: | Solid Black Ebony |
BRIDGE STYLE: | 1930s Style Belly w/ Long Saddle |
BRIDGE STRING SPACING: | 2-5/16'' |
SADDLE: | 16'' Radius/Long Bone |
TUNING MACHINES: | Nickel Open-Geared w/ Oval Buttons |
RECOMMENDED STRINGS: | Martin SP Lifespan Phosphor Bronze Light Gauge (MSP7100) |
BRIDGE & END PINS: | Solid Black Ebony |
PICKGUARD: | Delmar Tortoise Color - Beveled & Polished |
CASE: | 533E Geib style |
INTERIOR LABEL: | Signed by CFM IV |
Very nice. GLWTS.
Might help to garner interest if you indicate your approx. location.
Here is a good recording, same guitar model, same sunburst, it is even from the same year.
