Basically, I have a hair brained idea to turn my 90's Marshall 3x10 JTM60 combo into a head and 4x10 cab. Why? Exactly...I dunno, I don't gig, just for loud home use.
Anyway - a handy mate of mine is able to make an enclosure for the ampy bit thus leaving more room in the cabinet for another speaker. Now, I reckon that'll make for quite a good sounding compact package. Obviously a bit of work involved in this, new grill cloth, new baffle, wiring etc etc. I have me birthday next month so some cash may well be spunked on new speakers and to this end, 60 watts with a total load of 16ohms, the choice of possible combinations has me confused. I have read a few articles on the subject and as I'd like to keep things Marshally going Celestion would make sense. Golds are well out of my price range though!
Aside from the actual stupidity of such an undertaking, is there any advice you lot might offer as far as 10 inch speakers go?
That would be something like this:
Tip of Jack (Positive) -> Speaker 4 Positive
Sleeve of Jack (Negative) -> Speaker 1 Negative
Speaker 1 Positive -> Speaker 2 Negative
Speaker 1 Negative -> Speaker 3 Negative
Speaker 2 Positive -> Speaker 4 Positive
Speaker 3 Positive -> Speaker 4 Negative
*EDIT* The Tayden True Brit is 4ohms, £60 a pop though.
On the other hand if you really want a project, go the whole way and build a completely new cabinet - that way you can use ply, and ditch the crappy MDF shell Marshall used.
If I remember rightly the speakers in these are Eminences (they are in the other models), so either you want to find a similar Eminence as close as possible to the existing ones, or replace two or all four - a single different speaker in a set of four usually sounds odd.
I also worry that you'll go to a lot of trouble and expense and then the amp section will die, too… they have a tendency to, although they can be repaired at some cost. If you're going to make a head box for the amp section, make sure it's really well-ventilated, including a top vent - I don't normally like them but these amps have a bad record for overheating.
The JTMC 4x10 seems a rare beastie and most of the heads have probably gone to the great gig in the sky along with it's slightly younger and short lived JCM600 sibling. As the 3x10 Eminence speakers are rated at 5.3ohms each to get 16ohms the only way forward would be a complete replacement, which is prohibitively expensive for what is (as much as I like it) a mediocre amp notwithstanding the well documented issues. But my thinking is if/when the amp implodes I would then have a half about cab to partner a replacement head.
Marshall also did a 15" combo, which got me thinking I could find a cheap knackered one and use that as an extension cab but they seem harder still to find - one on Ebay for £495 though...not exactly a bargain.
Meh...as you might expect, the usual places will be kept an eye on for 2nd hand shiz. Keeps me interested innit.
