Hi there,
just wanter to show my custom built pedalboard for those looking for a small and light solution to accomodate few pedals.
I spent a lot of time figuring out the right solution in terms of size and weight and come out with this
Case is a DAP Audio SC-24 (costs approx 50€)
Top Level: Bluguitar Amp 1, Eventide H9 Max, TS-808
Bottom Level: Fulltone OCD, Rockett Blue Note, Voodoo Lab 4x4
Other: MusicomLab EFX 62M + Volume Pedal FV500H (works both as volume and Exp Pedal for the H9)
Routing: Line6 G50 Wireless, EFX 62M, TS808, Blue Note, OCD -->AMP1 --> Loop Send --> Volume Pedal / EXP Pedal --> 62M --> H9 --> Loop Return --> Bogner Cube
H9 Controlled via Midi PC and CC (Exp pedal + Program Change) through EFX 62M
Bluguitar Channel and boost controlled via Stereo cable from EFX 62M
Weights approx 11,5 kg / 25 lbs
Dimensions:
51,6 x 38,2 x 14,7 cm
Can I ask what your gigs are? Is this for weddings or the Dog and Duck? Or for a more serious level entirely?
I'm also curious why you chose the orientation of the lid/board with the catch at the front instead of at the back? Seems like that catch could cause problems or get damaged where it is.
Playing Rock / Pop music from 70's to recent music (only cover though)
The sound I can get is quite impressive for the size of the rig - in combo with the Bogner Cube sounds impressive
Haven't tried yet to go straigth to PA but will check soon!
DAP Audio SC-24 Profile is taller in the back, iw would't allow me to use the switcher easily. this is how is looks like empty
(basically is a case for the Showmaster 24 Mixer)
