OK, just about to get started with my second guitar build. I'm very happy with the aged look that I got on my first guitar, but I'd really like to try and get a nice shiny/polished feel to number two. I have limited facilities, so I'd like to know how to go about it - useful/good tutorials etc. I seem to recall that someone here got a good finish by painting on some kind of varnish first, smoothing it back then spraying afterwards. Does that ring a bell? I'll have to use spray cans rather than compressor for the finish, and my experience with those is that you can't really get a thick coat very well, so I'm hoping that the pre-coat with painted on varnish isn't just my imagination!
Adam
Adam
love tru-oil as an oil. Yes you can build it up like lacquer but it's not as hard and takes a lot of coats to get there.
Instagram
They aren't that expensive and you will never go back to cans afterwards.
Tip: an old wardrobe can be converted into a spray booth.
Tip: find a tame auto shop that has a spray booth and offer to hire it from them on Sundays or other days when they might be closed.
I'm lucky enough to have one 3 doors up from where we live.
i still I'll think I will stick with brushing the sanding sealer on, you can build up coats very quick and sand most of it off again soon after with very little waste.
Instagram
this one was done with spray can paints and a bottle of sealer from rothko and frost (dartfords brand), i have also used Chesnuts version recently. it has been done over mahogany without a grainfill. this means it will carry on sinking in and already has quite a bit since this pic was taken... if you don't want the sunken grain look you must grainfill too on any wood with pores. This one was levelled and buffed by hand too so it really was the minimum level of equipment
If you want the true PRS finish at home then it is worth looking into Rustins Plastic coating as its a much harder finish than nitro and easier to buff to a really high shine . It doesn't need sanding sealer, just use it undiluted for the same function. it still sinks in for the first few weeks but won't carry on the way nitro does I used this on a lot of my early guitars and a few other users here seem to be getting good results with it
Instagram
After visiting the Taylor Guitars factory this year I was very impressed with their UV cure system and wondered if there was anything like this that could be done on an amateur level. As you can really finish a guitar in a single day or less. Having done the Martin Factory last year and seen the productivity gains that Taylor gets and the quality of the finish my interest was piqued.
The only thing I have found so far is this but have not tried Solarez myself yet but it has possibilities.
https://youtu.be/xgSYSdou7Eo
Instagram
http://www.axminster.co.uk/chestnut-acrylic-lacquer-ax19769
