Currently thinking of buying myself a phaser pedal to get that subtle slightly swirly sound.
I'd prefer something with just one knob and just a mono out.
Probably overthinking things here but...
A quick Google search suggests that phasers often have model numbers which include 45, 90, or 100. I guess this is something to do with the degree of phasing going on - would that be correct? And do I need to concern myself with such things?
Also, I see that there seems to be 2-stage and 4-stage phasing. Again, anything I need to worry about?
From what I've managed to find so far, I'm liking the look of the DoD Phasor 201 and the MXR Phase 90. Ok, I know I need to go and try them out, but is there anything else I should be looking at?
Thanks.
The number of stages relates a bit to the number and to the maximum phase shift.
The Phase90 is a bit of a classic; I believe it's a 4-stage. I think it's probably the sound you're thinking of. I also really like the Boss PH-3 for the "rise" mode.
I'd also check out the new Phase 95. It's a mini pedal and has switch for both phase 45 or 90 style phasing and a switch to change between older more subtle phasing and newer more full on phasing.
Apart from the requirement for one knob, I would [stuck record] recommend the Boss PH-1R. Old, discontinued, but not too rare - and it can nail the sound of the Phase 90 as well as being far more versatile. Possibly the best standard-size pedal phaser ever made. [/stuck record]
Looks like the ultimate phaser.
I've had an orange 90 before which I liked but I fancied the 45 mode on the 95.
That or the EVH phase 90 would be my first choice, and in a close 3rd, would be the block logo Phase 90.
One has an LED and power socket (same circuit as the script button on the EVH) and the other is the 74 reissue, no LED or power socket.
Phase 100 - The Clash - Jimmy Jazz (or other London Calling tracks) and Rolling Stones - Beast of Burden (sounds good on the live version on the B-Side to Going to a Go Go single 1982)
