My advice would be to check out the Buffalo TD-X if you want an approximation (a good and usable approximation IMO) of that type of tone. Works off a regular 9v and can be easier to work with in low volume applications. May be easier to fit into your rig based on those two factors too.
http://thefretboard.co.uk/discussion/comment/319676/#Comment_319676
Main OP video is the Live Resolution performance
5th post has video demo by Andy of his whole rig and reasoning behind his choices, video 3 starts with the Tube Driver, end of video 2 demonstrates the clean amp tone for reference.
http://thefretboard.co.uk/discussion/comment/229076/#Comment_229076
Mine is a 3 knob mains powered bought from lovely chap @swlabr , great pedal and does exactly what I wanted into my Stiletto Ace. It is the same model Tube Driver as used by Andy Timmons.
@Gassage has had Tube Driver (s?) too, 4 knob I think.
There is info on the Gilmourish website too.
Some of the earlier ones are to be avoided.
I also have the BK/Chandler co-branded 9 band EQ rack model- which is very rare.
Fantastic things- but can be noisy (need to place the mains cable somewhere where it doesn't cause hum) and, unbeatable when you set them on low gain and you stack a higher gain pedal into them.
Will do mild to wild- like almost fuzz territory.
@philrob1 will mod one for you to take away the transformer issues.
Is the 9v version lacking compared to the mains powered models?
How about the one vs two tone controls - not sure I quite agree with his settings but Dan completely rolls back the bass and treble on the pedal show demo - which implies the single tone might be harder to dial in.
2. 2 tones, always. I crank the bass alsmost to max
The current 4 knob and 4 with bias are very, very good. BK has recently moved to a new layout which do sound ever so slightly different to the previous layout.
Tubes do make a difference, mostly in gain levels. As @gassage says, the CV4003 (12AU7) is a good place to start and Mullard ones can be had for fairly reasonable prices.
Another modification to the Tube Driver that improves it greatly is removal of the internal transformer. Significantly lowers the noise of the unit.
Also important to note that whilst the Tube Driver has a 1Mohm input impedance, it has no output buffer, so a buffer must be placed directly after it in the signal chain.
