Do your guitars have tone controls?
Not sarcasm by the way - these might not be the solution you're looking for, but it's easy to overlook if you aren't used to using the guitar controls. Small changes at the guitar can often fix stuff like this without needing to alter the amp.
I find that the sound gets richer, less spikey and the tone controls become more effective the higher you set the drive level even with a Strat. Running the AC10 "hot" just over the edge of break up and backing off volume on the guitar gives some great fat clean tones in my experience.
Great little amp!
http://www.theboxwoodchessmen.com/
https://www.facebook.com/tingiants/?view_public_for=231700547508938
My bigger problem with the amp is it's really loud. Anything above a whisker above zero and it feels too loud for my little office.
https://www.aliexpress.com/item/ammoon-AP-20-Mini-Guitar-Equalizer-Effect-Pedal-5-Band-Graphic-EQ-Aluminum-Alloy-Body-True/32738592576.html?spm=2114.01010208.3.213.ZTjkGj&ws_ab_test=searchweb0_0,searchweb201602_3_10065_10068_10000009_10084_10083_10080_10082_10081_10060_10062_10056_10055_10037_10054_10033_10059_10032_10099_10078_10079_10077_426_10103_10073_10102_10096_10052_10053_10107_10050_10106_10051,searchweb201603_9,afswitch_5,single_sort_0_default&btsid=2f8d118f-4c62-47d3-bff6-1480f157ee22
