You can play, there's no doubt and the sound, although i thought it had a little too much gain for that song, was fine.
What's not right is as @boogieman says the timing is off but also the structure of the song seems to lose itself.
Try going back to it and writing the song out on A4.
Structure it in on paper and remember what that image looks like, you will then see that on stage and remember the songs structure by that image.
If you go back and break the song into chunks, learning each one individually and then recognising where each section effectively stitches together it will help drastically.
Also listen out for contact points.
If you've never heard or heard of these, they're licks or phrases that are recognised by the band to signal the end of a section or even the song itself. There is a VERY obvious one played by DG, ascending the neck in whole tone bends at the end of the long second solo in Comfortably Numb. It actually signals the last few bars of the song.
You might find this and other songs you try to learn work better when you know their structure inside out.
I do something i call 'Immersion' whereby i listen to a song i'm trying to learn on repeat on headphones for a couple of hours, again and again. When i pick the guitar up i know what's coming next every time (Most times !).
That might help too.
You can play and you can definitely play THAT song, it just needs some finesse and confidence but it's a really gutsy attempt at a song that's not as easy as it might first appear.
Well done.
If you want any direct help, PM me anytime and i'll help all i can.
Learning by ear and playing covers live, especially at jams is what i did for many years and would still be doing now if my health would allow.
If you think i can help, just ask i'd be glad to.
You should practice along to some kind of backing track, a metronome or a drum machine. I've recently bought a Boss RC-3 looper, which has a limited range of decent drum patterns built in, which makes it a really good practice tool.
Once you've nailed your timing you'll be all set - everything else is good.
Hope you take this as intended - trying to be helpful/honest....
Just try playing the chords of the intro first to get the timings, e.g moving from the G to the E etc. Slowly bring in the key phrases he uses, then add your own touches. Also, don't worry about needing gain to give definition. Clean and some reverb will do it, and play different parts with different levels of force to accent it.
EDIT: Also thankyou @Alnico again for the ideas, especially the one about writing the structure down. This will help me massively x
Fucking really well done i really enjoyed listening to that.
Take *That* one on stage and you'll shine.
Keep practicing it every day like that and keep that inside-out knowledge of every aspect of it, like it sounds like you've got right now.
If i was listening to that in a pub i'd have a massive smile on my face.
On stage through a PA shouldn't be difficult from most devices.
I only have one more suggestion: keep the tone cleaner at the beginning and then wind the wick up when you go into the solo so you get a bit more light and shade. Otherwise, a very nice job.
Less gain on the intro though, just back off the volume on your guitar so you can whack it up as it gets going.
p.s. Welcome to the forum
Great phrasing, love the vibrato in particular
Ed Conway & The Unlawful Men - Alt Prog Folk: The FaceBook and The SoundCloud
'Rope Or A Ladder', 'Don't Sing Love Songs', and 'Poke The Frog' albums available now - see FaceBook page for details
