I decide not to buy the speaker in the end.
http://i.imgur.com/gND39Oo.jpg
Some small ones could be not an issue, but at best it's introduced a weakness into the cone and might cause odd overtones, and at worst it's a sign the speaker has been dropped and the frame twisted.
The markings on that tayden just look like chalk to me. Manufacturers often write on them like that. Looks harmless to me.
These are the two most common types of crease:
The small ones that form around the edge of the cone, and can turn into a tear or cut.
A long crease running along the rear edge of the cone.
Both are basically just 'wear and tear' from use in my opinion. Nothing to really worry about, but consider that the speaker has probably been very well used and may be past their best sonically. This is one of the reasons most speakers have doping, to protect / strengthen the cone from this happening. You might want to get the cone edge professionally re-doped, as it will re-stiffen the cone movement and prevent them tearing further.
I assumed by 'crease' that they meant something more like what happens if you carelessly throw a cable or a pedal into the back of a combo, but even then I'd want to see pics.
Now I can see it on a bigger screen I think the Tayden might be a bit of stray glue - so still nothing to worry about.
