I have an irig2 which i had hoped to use to connect to my macbook and play through its internal speaker. The blurb says it can be used with a mac.
Trouble is when one configures the mac's sound input/output, the internal speaker seems unavailable, though I can play output via bluetooth to an external speaker - but I don't want to lug that around too.
The only other possible way I can see is to use a cable between the irig2 cable/3.5mm jack and the USB port, which then might make the internal speaker available? - which means I need a female-female 3.5mm connector and a cable with a 3.5mm male at one end and USB at the other, since all the adaptors I have seen are male/USB.
Anyone had a similar puzzle?
Thanks
-site:amazon.co.uk -site:ebay.co.uk... ditto for .com, the most powerful internet search filters
You can try this though
http://best-mac-tips.com/2015/03/11/play-sound-on-multiple-devices-including-internal-speakers-os-x/
thanks again
