Since recently picking up an EC vibro champ I've started getting really facinated by these little amps and have decided to take the plunge and have a go at building a 5F1 champ.
So... where do I start!? I have zero experience so any advice, links to helpful sites, threads, videos, books would be extremely welcome.
I'd like the finished product to be top quality so opinions on where to source the best parts would be appreciated. Any good kits available or is it better (and more satisfying) to start sourcing parts myself?
Hoping this will be the first step of a lifelong obsession... I'm based in Box, Wiltshire (just outside Bath) so if any locals fancy sharing their knowledge please get in touch.
Good trades/sales with: Pluckbuddy, JDE, xXBADGERXx, Brize, alanchanxd, NigelP, Loobs, BusterCrabb, jimkehoe
Eqd Speaker Cranker clone
Do you have all of the required equipment - soldering iron (25watts) and sponge, cutters, thin nose pliers, tweezers, wire strippers, table vice (or similar), screwdrivers, small adjustable spanner, wire wool. 'Cos your going to need at least all of these.
Do you know the symbols used in simple electrical circuit diagrams? If not then bush up on this.
Kit wise, the Ampmaker WF-55 is a really great kit to start with - simple kit, simple layout, and a good sounding amp at the end of it all. This was my first build, and it worked well, however it then cost me a small fortune, and lots of aggro when I wanted to convert the build to a 5f1 champ replica, and in reality it's not really achievable with the WF-55 kit (due to the circuit using a diode rectified power supply rather than valve rectified - the ampmaker transformer doesn't have the taps or capacity to power the rectifier valve).
If you really want to build a champ then I'd start with a 5f1 kit from Modulus amps (on the forum somewhere).
http://modulusamplification.com/Champ-5F1-Style-kit-P5295732.aspx
I'll caveat the modulus amps link by saying that I've not (yet) bought a kit from them. And a difference with the ampmaker kit (particularly for the first build) it that Barry gives step by step instructions.
I also see that Ampmaker are now setting up an on line building course for one of his amp models, might be worth waiting for that....
I will never sell mine!
At the moment I have a screwdriver and that's about it. @MtB - Any recommendations on soldering irons etc? I'd rather buy quality, once.
Clueless about circuit diagrams and electronics too. Definately up for studying as I go. Any suggestions on where to start?
Me too! But the instructions made it easy....
If you've not got any experience then I would definitely recommend an Ampmaker kit - the instructions are great. Once you've learned to solder, read circuit diagrams, etc. you could try something more authentic. The Modulus Champ kit looks pretty good (£210, or £395 with tweed cab) but doesn't come with instructions so you'd need to know what you're doing.
R.
Chris Uff's name has come up as a good cabinet builder. Any other recommendations for laquered tweed cabs?
R.
