Trading feedback | FS: Nothing right now
JM build | Pedalboard plans
Yes, I have an HA400 and it is a super little box for the money. You will need a special lead to go from HA to line out.
XLR, I am guessing 3pole female plug to stereo TRS jack plug and the tip and ring need to be linked of you want sound in both ears. The fly in the emolument is how the XLR is "balanced"? Could be a transformer and in that case pin 3 becomes common (sleeve) and hot is pin 2. Could be fully electronic, two amps in which case pin 1 is common and you just need pin 2 hot. Last variant is "impedance" balanced. Pin 1 common, pin 2 hot.
You might also consider a small mixer such as the Behringer 502 or 802? Can often be found in S/H and charity shops.
Dave.
Do you mean from the attenuator XLR out to the HA400 input? I'll check with the manufacturer. It's a Sequis Motherload Elemental, and Rick Cawley has been helpful with queries in the past. And in that case, I wouldn't need a special lead, correct? i.e. I could connect the mono attenuator output to a mixer input, and send it to both channels of the headphone output.
It's a useful little box
