She got slightly nervous and a bit clingy (she's a bit of a velcro dog anyway) and her appetite was up and down, but otherwise fine.
We kept her on a long line or lead and told other dog owners that she was in heat and everything was fine. She also goes on pack walks which don't allow whole males and are in fenced grounds with constant supervision so we made it through OK.
This goes double if, like ours, your garden is surrounded by others with dogs.
Another thing (which is usually a bit more breed-dependent) is that females in heat will sometimes try to attack other female dogs.
Apart from that...have a mop and bucket handy. When Coco had her first (and only) season, we tried the t-shirt-as-a-nappy method of keeping everything clean. First thing she did was run outside for a dump...I'm sure you can guess what happened next.
We're fortunate in that the entire back garden is surrounded by 6-foot fence, and while Sprocket is bouncy she's not much of a jumper.
Yes. She went through the fence.
I should also qualify my first response with the disclaimer that there isn't really a "this will happen" with these things, only "this can happen". It's wildly different according to temperament, size, breed etc.
Sprocket practically demands at least an hour of kicky-ball in the garden a day in addition to at least 2 hours of walks.
Kicky-ball, for reference, is where she runs around with one football in her mouth while someone else kicks the other football at her regularly. If you stop kicking the ball at her she pokes you with her nose until you get with the programme.
We are partly relieved it's finally come, as we've been anticipating it for weeks/months! and it would explain her erratic off lead behaviour the last few weeks (just bolting without warning and not coming back - just charging up and down hedgerows, going bananas).
Of course, there's the other side of the coin with larger breeds where if you don't let them have a season or two, it massively increases the chances of joint problems due to an imbalance of hormones relating to growth.
You probably already know that, but it's worth stating for any drive-by readers
She is now speyed thank goodness
Do not excercise a bitch in heat unless you really have to in which case wash her bits with white vinegar water beforehand and use bitch spray on vulva region........make sure she doesn't urinate when out on the street
But ,if you don't have a male at home I don't see the problem other than a bit of mopping up
I have huge experience of large/giant breeds........and 2 vets in the family .....you are not wrong but it's not conclusive
the principal concern is pyometra far above the risk of FCE although in larger breeds calcification of joints is pretty much complete by 11 to 14 months.
The greatest threat to joint and skeletal problems other than breed specific genetic susceptibility is over balance of protein in the diet ,imbalance of phosphates and calcium and especially over - excercise ie ;the strain on bones and joints that are so rapidly grown and still semi-cartiligenous rather than fully calcified . Giant breeds for example should not have more than 10 minutes free excercise per day until they are at least 9-11 months .Impact damage from allowing dogs to climb steps and stairs or jump out of car boots etc until all bone is fully calcified is the proven cause of most joint/ skeletal damage especially in heavier breeds .
Get a dog with a cock seems to be the moral of the story.
Also chips are "Plant-based" no matter how you cook them.
