Replacebase are good for Sony, not had any probs with batteries and screens from them
https://www.replacebase.co.uk/sony-phone-parts/
You might wanna buy a gasket as well as your generally harm the old one heating up and removing the back cover
Yes Ebay and Amazon are absolutely the last port of call due to the utter scum that often masquerade as traders.
http://www.thefretboard.co.uk/discussion/61134/sarge/p1
http://www.ebay.co.uk/itm/Sony-Xperia-Z3-Mini-Compact-D5803-D5833-LIS1561ERPC-1282-1203-1-2600mAH-Battery-/172113211131?hash=item2812bf2efb:g:ZEgAAOSwzgRWzfnr
You'll need a battery cover too as sometimes they snap when they're removed to get access to the battery ...
http://www.ebay.co.uk/itm/Replacement-Battery-Back-Rear-Glass-Cover-Housing-Sony-Xperia-Z3-Mini-Z3-Compact-/272242596378?var=&hash=item3f62ec5a1a:m:mY3WxslwOWPPKJA8-5h5ONA
If you use plenty of heat and a thin plectrum to remove the back you should get it off without it breaking ... the trick is not to rush or pry up too much
