Any fans of Newtone?
Any comments on the relative merits of their standard acoustic strings (called Master Class, I think)... and their low-tension acoustic strings (Heritage)?
Thanks
Their Heritage range are the best low tension strings around if you are looking for something a bit lighter on the fingers or for a guitar with a fragile soundboard.
Gents... thanks for the feedback.
@Winny_Pooh and @daveww which model strings are you using... Master Class or Heritage... which gauges... and on what type of guitars? Thanks
@daveww. Thanks for the info. I'm interested in trying some lighter strings (I usually use Daddario 12 to 53s). Do you find the 11-50 gauge Newtones have enough 'tone'/volume... and enough bass?
Thanks
Newt’s has option on their site for NC’s u could just email them and ask for a ‘custom’ set of Heritage - never know.
BTW Newt’s site is at present being updated - expect glitches
another option is Eagle Music which sells Newtone PB strings in various gauges and even a ‘pick u’r own gauge.
DR Rares’ are ‘low tension’ - they play with the gauge of the core wire to achieve this - again just email them and ask bout lb’s tension.
Pay attention to key words like ’Normal’ / ‘Low’ / ‘Flexible’ on the string sites.
note their Sunbeams are normal tension but on a round core - making them (as they say on the site) ‘slightly’ more flexible, folk’s ( in the stats) get confused with flexibility / lower tension - they also call ‘alternative (tuning from standard) ‘alternate tuning’ and cant distinguish between an ‘Authentic’ guitar and a reproduction (read copy) when it means -
genuine, original, real, actual, pukka, bona fide, true.
Then theres string life - longevity - they think the strings ‘kill’ themselves - nothing to do with the players skin excretion’s - sweat / oil..
Gentlemen... many thanks for your help and advice. I'm going to order a few different variations on the Master Class and Heritage versions... and do some experimenting. From your comments, it sounds like it could be very interesting.
Again, thanks for your help.
Update... put a set of 12-51 Newtone Heritage - Low Tension strings on the J45.
Wow... they are really low tension. Very noticeable. Make the guitar waaay more playable (which is a good thing for my wusy fingers that are more used to electric strings). I think the guitar is very slightly quieter (I expected this... as there's less tension being put into the top of the guitar). Maybe a touch less bass than the 12-55 80/20 strings that were on the guitar before (think they might have been Ernie Ball strings. Whatever they were, they were normal tension... and obviously the 55 is likely to produce a stronger bass)... but the difference in playability more than makes up for this (and the bass is still strong).
Very impressed. I think Newtone has just won a new customer.
Update...
Still loving the Newtone Heritage Low Tension 12s on the J45. As I said... it's lost a slight touch of volume... but still sounds fine... and much easier to play.
Have also tried them on a Lowden F.... and they're a bit louder than the strings I'd been using on it (Elixir phosphor bronze, nanoweb 12s). Weird... not sure how a lower tension string can produce slightly more volume... maybe it's the absence of a coating on the strings... or something to do with the guitar having a cedar top?!?!?!?
Anyway... I'm a Newtone convert.
Feedback
they're better quality strings in materials and manufacture - that simple.
Big string manufacturers manufacture too a cost and shareholders dividend - likes of Newtone cant compete with that so rely on producing a quality product to get the sales.
I've often wished BIG string manufacturers would make a higher quality line of strings - would be interesting.
All this said good strings are killed (by the player !) more quickly that $5 a set ones so if thats you - better stick with the lower quality product - Americans typically are of that mind.
Thanks. Food for thought... but doesn't necessarily explain why the same strings were quieter on the J45 though.
That said... I'm happy with the Newtones on both guitars.
