Blackface Princeton (non-Reverb) - what I should be paying for an original amp?
SunDevilSunDevil Frets: 511
Are these well regarded amps and will it do the blackface thing for me at home volumes?
Any tips on what to look for?
Baz
  • ICBMICBM Frets: 72307
    They're OK, although quite clean and a bit flat-sounding compared to the Princeton Reverb, even if you're comparing them with the PR's reverb off - that's because the PR has an extra gain stage after the reverb. As a result they're worth about half what a PR of the same year and condition is.
    if you want the characteristic Blackface tone, personally I'd buy a Princeton Reverb Reissue instead.
  • SunDevilSunDevil Frets: 511
    ..glad I walked away from it now!
    It sounded pretty nice, but not a hint of breakup, even with P90s
    I'll certainly check out the reissue before I take the plunge
    Thanks @ICBM ;
  • cbellangacbellanga Frets: 572
    I have a 64, it won't break up even on 10. Mine has a celestion gold and it sounds great for a clean platform.
    Yep - I also found it incredibly quiet - played a modern Silverface reissue today and it had way more output.
    I'm sure speaker sensitivity is part of that (the 64 had an Oxford) but I was still surprised
