Anyone used this set up before?
Looking to get myself a little 112, these speakers sound rather interesting... I usually use v30's in a 212 (though i'm trying to swap these for wgs vet 30's). I'll be using either a 70w MJW (hot 800...) or a 100w jcm900.
k-100 seems an obvious choice as its got the power handling for either amp unlike a single v30, and its supposed to be quite a full sounding speaker.
I like quite a thick sound as opposed to bright. Definitely not a greenback fan. I'd sooner have a fairly dark sounding speaker and have to add treble from my amp rather than worry about cutting treble from a bright speaker! That's also why I'm chasing vet 30's as replacements for v30's!
Opinions appreciated. Second hand K100's for sale appreciated even more haha!
Thanks
Chris
Another possibility is a Marshall 1912 cab which comes stock with a G12B-150, which is an even beefier version of the same thing, probably more closely related to the old G12H-100 which is definitely a true 100W speaker.
if I used the 900 with it I doubt I would ever run it close to flat out so chances are it would be safe?
To be fair, the amp (or possibly amps) which I've seen blow them were solid-state combos, which are actually harder on speakers than valve amps are, even though they don't seem to sound as loud.
