Does the L2 do the job for bass as well? Where PA is present I would go DI out from Helix and use the FRFR for monitoring..
I'd consider a little lightweight bass combo and EQ your guitar patches to suit. My Genz Shuttle is darned near as loud as the L3S was in a package less than a quarter of the size, and I can pick it up with one finger.
I'm loving the tone I get both bass and guitar from the helix either with headphones or the Yamaha monitors I have. I guess I'm just after something that will give more of the same in a powered box for stage use.
Ok, so I can chuck the helix out to FOH but I'm looking for a complimentary solution for monitoring/when the pa can't take it.
I have to admit the L3 series look perfect - apart from the weight and size! I wonder if the L2 will do the same job - I'm a 4 not 5 stringer so suspect the bass response would do the job on the L2? They certainly seem more manageable.
My worry with a combo would be having to tweak the Helix patches and it not being the same as is required for FOH.... eugh.
Maybe I should try an L2 and see if it gets close?
I could hook up the GB to my Helix and see how it compares to the Presonus Eris e8s I normally use if that'd help?
My plan is to get a set of patches set up and then not bugger about with them too much - more playing less fiddling
In the meantime I might try to find a shop where I can eyeball these Line6 L2 and L3 jobs and see how heavy/loud they are..
it at least has wheels
in my experience (I have both hat I use for PA) the L2 won't give you the depth of bass you are looking for
I have 3 configurations for that PA
1. 2 X L2s and a sub
2. 2 X L3s no sub
3. 2 X L3s and a sub
at no point do I think the L2s can cope with the bass and the BD without a sub
Thing is, the weight of the L3 isn't that different to a non-lightweight decent bass cab, and I can use the L3 to feed a monitor from the PA in and mix that in as well...
Before I pull the trigger, does anyone have any alternate frfr choices I should look at before purchasing?
