Very very nice, flawlessly put together but leaves me a little cold.
I have a regius 6 with bareknuckle blackhawks in it. Its swamp ash wings with the 11 piece neck.
Neck wise it's a fairly flat radius (similar to LP) and is a split between a modern U and modern C. Slightly deeper than my PRS wide thin neck and a wide-ish nut closer to the LP. Not that shreddy a neck IMO.
Sound wise (pickups are a huge driver here) the split coil tones are very clear and will cover most bases. The pickups are fairly hot so any low gain blues stuff I tend to roll down the volume a tad. I expect this would be easier with lower output pickups. Pretty even response across the neck as well.
It has quite a bright attack if you are coming from an LP but is a full sound nonetheless.
As discussed previously they are very well made, mine is pretty much flawless and I can only say that about my PRS....
Where are you based?
