Depends what you want really. Flexible routing, USB interface, loops for pedals, lots of complicated dual paths - Helix. Bit more straightforward, better sounds, optimised for 4CM - FX8.
I've gigged FX8, Helix and AX8 and all sounded great, but I personally prefer the sound of the Fractal stuff
I tend to use the FX8 like a pedal board (scenes) but the option of other amps (modelled) and being able to record etc are appealing. Practicing at home with headphones too.
From a practical point of view - the built in Exp pedal which can go from Exp to Vol or Wah etc is great and the fact every thing is lit too - my FX8 is dark on stage apart from on the button that is selected. Editing on the fly with your foot and the exp pedal is very clever too.
Floor noise and channel switching are important too - I know how good the FX8 is so I'm maybe just being lured by bright lights and new toys I watched some vids and at the back of my mind I keep thinking "The FX8 can do that, and that" etc
There's also that looming "direct to PA with IEM" way of working that I'd like to get to one day
Mainly for the direct options as well as the 4CM stuff.
Was a little anxious as t'internet wisdom makes you believe that the FX8 is the only 4CM unit and Helix is not as good - absolute bollocks IMO - the Helix is totally quiet and transparent PROVIDED YOU READ THE FUCKING MANUAL!! OK, the FX8 is perhaps a little easier to integrate 4CM wise as that is all it will do and its hard to get it wrong, but the Helix once understood is just as easy - the reason Helix is perhaps a little trickier to get right is due to it being infinitely more flexible with how and where you can route things.
As for the effects, I'm not missing the FX8 lets put it that way and I get to go direct and have an instant back-up rig at my feet and the option to run different pre-amps into the poweramp of my real amp at the touch of a button..
I also don't have to worry about those magnetic Kick Tag things, its all built in and they change with my patches.
And I don't have to worry about an expression pedal or volume pedal.
And I don't have to deal with the Church of Cliff.
And....
So in 4CM I can have a modelled amp using just the power amp in my Victory (and no Cab sim) and the real amp as another option - I think that's how they had it in the vid I posted.
I have also got it set in such a way that I no longer need to mic up - so I run the amp and a direct FOH (straight from the real amp via an IR of my actual cab) which gives our PA a constant signal every night of the week
Used my Helix in 4CM, direct FX only in to a real amp, and now I'm using it direct to FOH with a FRFR monitor, it's been brilliant in every application, and sounds fantastic too.
Haven't had a lot of time with a AX8, and it's probably just as good.
The firmware updates for the Helix are coming thick and fast, what was already a great unit gets better and better with every release and they don't seem to be slowing down.
At least I can start 4CM and work to direct!
How much is the fx8?
I run either a 1x12 ported Bogner or its bigger brother the OS212 on stage and I am then running the 412 Bogner IR to FOH, with the ontsage and FOH it sounds massive!!
Also remember that you can (via snapshots on Helix) switch in a different IR (say a Deluxe cab) for your clean and (as I do on a few patches) a Mesa 412 for the heavier stuff.
Never played with an AX8 but I'm not sure the Fractal can do this - the Helix is more a competitor to the AX8 than the FX8 really - in the FX8's defence, the Helix is always going to win IMO - the AX8 would need to be pretty damn sharp too to come close to the Helix - there's no "quality" difference between them, its purely flavours!!
Only thing I will say is that you will need more than a shop demo to get to grips with the Helix - I'd be tempted to do the distance selling thing and have a good session with it in your own time.
Happy to share my patches with you if you do get something.
