I love my Fender Telecaster but I find the neck pick-up is sometimes way too bassy. It seems very sensitive to particular amps and distortion settings - with some it sounds fine, but with others you flick the p/up selector and its just way too dark & muddy. I don't want to change the pick-up as I'd like to keep the guitar original but is there anything I can do to make the pick-up brighter sounding? I was wondering whether this could be improved by altering the wiring somehow with a cap or resistor (sorry, I'm not a tech so apologies if I'm using wrong terminology or if this can't be done).
If not, and a p/up change is my only viable option, what would be a good p/up choice?
The difference varies between subtle and quite noticeable depending on the pickup, but it may be enough. The only downside is very slightly increased noise.
https://www.reddit.com/r/Guitar/comments/4lbgqz/oc_useful_guitar_mod_bass_cut_pot/
http://www.metalguitarist.org/forum/guitar-tech-electronics-and-diy/773-tight-control-simple-passive-bass-cut.html
Even the Esquire wiring was devised to also give a BASS application.
The neck pickup in my 2015 American Vintage 52 is not as sassy as I recall a Tele pickup, it's nicely balanced with the bridge pickup. The Twisted Tele neck pickup is also more Stratty.
But, the best pickups I have used in a Tele are the Custom Shop Nocaster 51's, a great set of pickups. You can't go wrong with them.
The AV52 stock pickups are close enough for me to keep them.
If you don't like your pickups - change them.
