Would seriously doubt you need any special springs.
If you want the bridge not to move, you need to put a block in the cavity which will hold it at the proper angle.
do you want it to not move at all ? - or do you want down pitch only ?
If the former, then a 'small wooden block' like a domino, can be be inserted between the trem block and the body - Done correctly the trem plate will still be in the correct 'floating' position (ie effectively parallel to the body), but you'll have no trem movement at all - simple to reverse at a later date if required
If the later then not really possible with the PRS trem system
It's a little tricky to get the blocks the right thickness though - I can't remember the measurements. Essentially when they're correctly fitted the bridge block will be held exactly at right-angles to the body so the bridgeplate will be parallel.
It was fine until I put 10s on.
The higher you raise the saddles, the more tension will be required on the springs, to counteract the string tension. Likewise, if the string gauge is increased.
In years gone by, PRS shipped with 9s - so the factory set-up on an 18 year old guitar is likely to be optimised for these.
You might find raising the screws at the leading edge of the bridge plate - and dropping the saddles - achieves a higher action without compromising the functionality of the trem. The key thing is to adjust the six screws without string (or ideally spring) tension. The grooves machined into them should be perfectly in line, to allow the bridge to pivot accurately. The knife-edges in the bridge can be easily damaged under tension - so be careful.
Suitably levelled - with a couple of springs attached - the trem system should pivot freely. At this point, you can string up and add the other springs. The leading edged height screws determine where the fulcrum point is - set higher - with the saddles lower - it should be easy to get the bridge plate parellel with four springs.
They were lower than stated on the Prs guide, must have been adjusted when it had a fret dress snd set up at dome point.
I lowered the saddles and re strung. I did find a 5th spring which I fitted and had to loosen the claw a few turns to balance, but I don't kind a stiffer trem.
Trem is now parallel to the body, and the low e pulls up to f# which is as per the Prs guide.
Might take a spring off at the weekend and see if it balanced with 4.
