No doubt ICBM will be along with the real dope presently? In the meantime, the wire combination that gives the highest DC resistance will be for 240V. This needs care to test as the resistances will be low and the difference small.
I assume you have a meter? No one should ever be poking in amps etc WITHOUT a test meter!!
N.B. If you do adjust the tapping you MUST get the amp PAT tested before you sell it. I am in general unhappy about persons of unknown ability messing with mains side wiring!
Dave.
For what it's worth the warnings in that Rat Amps link are too extreme. The amp does run hot, but it's not in danger of burning out the valves in two hours. Thousands of people use these amps without correcting the voltage and they just run a bit hot and shorten the valve life a bit, nothing more than that.
I agree up to a point. In fact it's really a good idea to have anything mains-powered that you're going to sell checked.
The problem is that you can't always trust the tester! I've had two amps through recently which had been recently 'repaired' by other supposed professionals, which had the mains plugs incorrectly fitted and that had not been noticed, let alone fixed. In one case the earth wire was broken because of it, although it appeared to be connected.
I suppose to be fully sure I need to be measuring voltage before and after ( something I am a not happy doing without someone qualified ) or seeing a
By a curious coincidence I've got a job incoming tomorrow which is a Blues Junior (older version) which has "fried itself"…
if you do decide to do it, might be worth taking a couple of pics of the wiring as it is now in case it had to go back for any reason.
Should be between 216v and 253v
Not sure if that helps anyone.
I too have a brand new blues junior 3 that fender have replaced for me as my last new one was redplating also. (Even after being sent away for repair)
I want to do this mod switching the wires to convert to 240v but i have bot the confidence yet to do so. Is it simply just a matter of switching the wires around?
Will there be any noticeable difference in the tone of the amp?
Apart from warranty issues, are there any other negative outcomes of doing this mod?
Just need the reassurrance to switch the wires and know the amp isnt going to blow into a ball of dust when i switch it on.
It will get a little cleaner and less middy, but not a lot.
Absolutely not, it's better for the amp all round.
Thanks
If it's really too tight for that, try to get some sort of tool under the bottom end of it - I have a purposely bent small screwdriver exactly for this sort of thing, to use like a miniature crowbar.
Is there any other wires that can be removed to make accessing p6 any easier. ?
I could easily get to it by removong the clear glass fuse next to it but not sure if temporarily removing the fuse may screw anything up.
Thanks
