It sounds like something in the switching control circuit. The reverb switch is purely passive (just grounds the reverb output) so that won't be affected.
It's actually a small push button on the VC15 but that should probably still work if you're liberal with the switch cleaner.
thanks @ICBM good to hear its def not its not a valve thing
No, that's a bad thing - since if it's not the panel switch it's now going to be something more expensive to fix than a valve.
Worth trying the contact cleaner first anyway, it's something that's always useful to have.
Or maybe it was the other way around... Completely useless comment award?
