So good Vertex removed the Boss labelling, claimed it removed any tone suck and sold it for an inflated price, and American gear-heads bought it… and the pedal.
Its the lettuce of the fx world.
Also because using your volume knob is a pain with a noise gate. A volume pedal after a noise gate means the gate always sees the same signal so can be left on permanently. I get my gritty low gain sounds by backing off volume so this is much more practical for me
that's my use anyway.
I use one of the expression pedals on my Tonelab SE as a volume control to go from rhythm volume to lead solo volume on patches where I simply want a volume boost with no change to gain levels.
On other patches, I'll set it to control gain level in a similar way to the guitar volume knob but with the advantage of no tonal drop off. I realise the latter is strictly using it as an expression control, but some free standing volume pedals can do that too, so seemed a reasonable comparison.
And like certain volume pedals I can set the range between toe down and heel down, or leave it as full sweep if I want.
With my conventional pedal board I use a simple passive Carlsboro volume pedal. This is full sweep only with no parameter control.
With my Valvetronix AD120VTX, I have a dedicated volume pedal on my VC12 floor controller. This allows setting to one of three sweep characteristics - not as controllable as the Tonelab, but still useful options.
