There's various ways around this generally. First up try and talk sensibly to the staff, tell them your stay under the limit but you would prefer not to have the mains cut if you do momentarily exceed the limit as your desk is digital and damaged by power cuts . So can you power the band off a socket not on the ring controlled by the limiter
If that don't work look to see how the limiter is wired. If it's external mic then an inline voltage divider is my normal tool , basically 3 resistors in a cable but some use XLR, some use 3.5mm or 1\4 jack
Finally if all else fails use a large UPS. I have a large 8U HP UPS capable of putting out 2.2KW for 12 mins and if need be I will run the whole band from that ... when doing so the limiter tripping the mains has no effect at all on the band
Pretty pictures of stuff and things here...
My Feedback thread here...
90dBC Fast would be very, very hard to manage - whereas 90dBa LAEq 15mins is very definitely not unachievable for a live band..
I would always suggest you go back to the venue and ask exactly what specification they are measuring to - and of course, checking that their measurement equipment is within Class II calibration specs.. This is often enough to make them realise you know what you're on about, and go away!
But it's not unachievable to play at 90dBa average - yes, your drummer will need to reign it in a bit, and no marshall stacks all at 10... but it is doable! Do things like - mic amps up/di, and use the PA as much as possible, if any of you are happy with In Ears, use them to cut stage noise..
(Having said that, *if* it's politically acceptable, Danny's solutions also solve the problem a different way!)
In general I don't have a problem with being asked to play quietly, but limiters are a major pain in the backside if they trip and I would probably refuse to play the gig if running the gear from one is a condition of it. Fair enough to use it as a guide, but risking damaging your gear by having it crudely shut off isn't.
That said, it surprises me that any gear isn't designed so it's not possible to damage it if the power fails for any other reason either, but it does seem to be.
I was out last night with a seven piece soul band in a venue with noise restrictions - drummer played with rods, bass and guitar through the PA and backline right down low so it was just enough for a splash of personal monitoring. Yes, the vibe on stage was a bit crap compared to when we can play "properly", but the dancefloor was still full and the client was still happy. If you're going to do weddings, you'll run in to it all the time and will just have to come up with a way of dealing with it.
The manager at the venue was telling us how much of a nightmare he has with bands over it, people trying to be rock and roll and announcing over the mic that "we've been told to turn it down so we're going to turn it up". It's self destructive because you end up no longer being welcome at the venue, or the venue gets one too many noise complaints and has to stop having live music altogether and there's one less place for us all to gig. We were understanding and co-operative and left having been invited to quote for two more weddings that the manager was booking in for friends of his, and to consult on their new sound system installation!
They had complaints about noise from said Caravan park pretty much from week one, and had to install a sound limiter which was set at 90db, which is literally nothing in a huge Marquee.
We played there twice last year and had alot of problems. We got through both gigs, just, but not without a lot of complaints, mainly from wedding guests for us to turn up!!
The 2nd time we played there we got the drummer to take his high end Roland electronic kit, as the acoustic drums caused all manor of problems the first time round.
We had the bride and groom on one side of the stage complaining they weren't getting there monies worth and asking us to turn up, and on the other side of the stage we had the hotel events manager shouting at us to turn down, we were literally stuck in the middle.
We tripped the power a few times which in turn blew the fuse on my amp, so then I had to scramble around trying to sort it out (Ended up going direct to the desk). It was all a huge pain in the arse.
We were documenting the problems we were having throughout the evening on social media, which in turn the hotel events manager seen. She subsequently told us we must delete all of it as it was bad publicity for her venue, and the limiter would scare of bands which would in turn scare of potential wedding clients!! No shit Sherlock :-)
Safe to say we haven't been back and any enquiries that have came in we have had to advise that it's not possible for a band to play there.
I will no longer play anywhere where they won't guarantee an electricity supply, we're actually at work trying to do a paid job, the same as a plumber or bricklayer would be.
We were once booked for Ludlow assembly rooms and there happened to be a poetry recital in the room next door. The woman running the recital saw us dragging drums an amps in and asked us to keep the volume down.
We duly soundchecked very quietly, and just as she came smiling back into the room to tell she couldn't hear us at all next door the limiter cut our power off - even she was horrified by how sensitive it was.
We couldn't play, the police were called when the punters went nuts at the council guy who'd been summoned and we made him stand on the stage to tell everyone why a very expensive 60th birthday party was cancelled.
What really pissed me off is that they have name bands at that venue all the time, you can bet they don't cut their power mid song.
I've setup a lot of venue limited over the years. It's weird that they are doing the limiting using handheld meter which suggests to me that the issue hasn't escalated to Local Authority enforcement. They would normally demand a calibrated microphone system that either: 1) shuts off power, or 2) has a 'level controller' box that you have to insert inline between your mixer and power amps (this doesn't deal with backline sound energy though)
If I was in a wedding or function band I would definitely be making sure that the contract the bookers were signing (you do have contracts, right?) had a very clear clause along the lines of "if your venue has sound limiting, then that's your choice---don't then ask us to turn up the volume, disappointment not our fault, etc etc etc".
As a wedding band, it is a given that you will play venues with limiters. The drummer needs an electronic kit, unfortunately. Not cheap being a drummer in a function band!
You're right that the couple might not know, but the band should prompt them to find out---just as they should also prompt them to make sure that there's enough space/power etc available too.
