Out of interest, I took the guitar outside and over the road with my Blackstar Fly and there's definitely one distinct angle where the interference clears up. Lots of overhead powerlines
My band, Red For Dissent
I used conductive paint on my Gordon Smith with P90s. I took off all the electrics and applied three coats of shielding paint, including all the wiring routes. I allowed each coat to dry for 24 hours, just to be sure and it really helped. I don't think you're ever going to make a P90 totally hum-free, but the pickups I have installed are Fralins and after the painting, the improvement was amazing. It's now totally manageable.
I'm not sure how one would do it on a semi-hollow but I'm sure it's doable. Check out youtube for tips.
The clue is that it goes away at a specific orientation. If it's universal no matter how you orient the guitar, it's electrostatic noise or ground loop hum, in which case shielding and/or star grounding will help.
The solution to electromagnetic noise is humbuckers...
http://www.ehx.com/products/hum-debugger
Worth considering?
That's why any guitar I intend to gig with has at least RWRP single coils, if not full humbuckers - so at worst, the two-pickup sound is hum cancelling. Just occasionally you need it, even if it's not necessarily the sound you would want to use.
I have a tele deluxe with humbuckers and it makes a lot of noise until you touch the strings, or bridge. Then it's quieter.
Would shielding help with that?
Well not exactly brilliant, but you know what I mean.....
