Wouldn't your average desk have most of those things, except the balanced XLR out?
If I use a passive pickup with the passive DI it seems to be a very quiet signal and they have to whack the gain up on the desk.
You do need some sort of power at some point, so if you're not using a pedal or an onboard preamp then you need an active DI box, or the pickup itself is having to drive the whole length of cable to the desk.
Aye, that's the reason I went passive (with electro-acoustic); I wanted the transformer tonez! I have a soundhole pickup for emergencies, and I suspected I need active DI for passive pickup. Good to have it confirmed by someone who knows about electrickery.
Seriously, if my Takamine preamp ever fails again I will be getting a decent soundhole pickup and an external preamp!! But then I'm preaching to the choir here.
Nice one @crunchman, I hadn't heard of them. The Micro DI looks like a nice backup to go with my passive pickup, and a lot cheaper than a Radial JDI!
Pretty pictures of stuff and things here...
My Feedback thread here...
I was just bemoaning before about the lack of 9v adaptor-compatible DIs.
Another +1 for Orchid
At a push the Behringer active DIs (Ultra DI & DI20) work for this but the ultra can be susceptable to noise (the unit they copied had a mumetal can for screening the transformer which for cost sake Behringer ignored) if stood atop an amp with a big mains transformer. They are readilly available and reasonable performance, but Orchid would get my money again if I needed more DIs and are similarly priced for UK made product with excellent reputation.
The guitar in question seems to have a built in pre amp? If so then yes, that can drive a line input of the usual 10k load impedance but as ICBM said, the guy on the desk will likely want a mic level feed on XLR and so a standard DI box, active or passive (the Orchids handily run from phantom power).
If however you have a passive, peizo pickup that needs a pre amp and said pre amp needs a much higher input impedance than the standard active DI box or indeed guitar amplifier. In the order of 5 to 10 meg Ohms. A one meg load will make the guitar sound very bass light. (one dodge you can try at home is to feed one into the RIAA corrected phono input of a hi fi amp)
I also doubt a guitar would drive a transformer nearly hard enough to elicit any "transformer tone"? Traffs DO distort but not much until you hit a volt or so and even then only at low frequencies, mostly those below the E string!
Seems above is right. A Radial passive quotes 0.05% THD at -10dBV (abt 300mV) and another make, 0.01% at +4dBu. Sowter make a 10:1 traff specifically for DI boxes* and that does not hit 0.5% THD (still undetectable) until the input level is 40 volts!
*Will be expensive!
Dave.
