I've been using a Fender HRD combo for a while now, running clean with dirt from pedals, but I'm thinking of going back to a head/cab set-up using the amp for dirt. I have two Zilla 2x12s.
Needs to be two channels, one clean, one dirty. Classic rock levels of gain, anything else and I can use pedals. Needs an FX loop...and loud enough for pub gigs without being mic'd up.
Looking up to around £700 I think.
The incoming Jet City Amelia is tempting, as it the incoming PRS Sonzera 50, obviously can't try those yet (and doubt I'd be able to try the Amelia anywhere), but what else should I consider?
It has a really beautiful clean channel, loves pedals, good classic rock crunch on the dirt and it has a clever global tone control so you can rock up to any room and dial it in really easily without needing to tweak all of the knobs - you just dial how bright or dark it needs to be (so set it at 5 or so at home).
Loud as fook, excellent tone, bright switch on the cleans will let you get tones you'll associate with a fender amp if you wanted. Mine was reliable too, but a bit of a pain to get to the valves.
They're bloody affordable these days. I paid £400 for mine new years ago, but I've seen them fetch as little as £150 on ebay. That leaves you enough change for a fabulous custom cab.
It doesn't even have to be my JVM, but the JVM gives you four channels of absolute classic amps in one head, a really good FX loop and two Master volumes. I.e. you can kick the second one in for solos and always be heard. You can also do a neat thing where you can set the FX loop to act as a solo boost too if you want, so like kick in your echo and get a boost as you do so. And it's a 100W Marshall head so even with just one 2*12 it's definitely loud enough! Lovely amps.
