About a month ago my hifi amp developed a fault. From phono there was no sound from the left speaker, from the CD player there is sound from both speakers but really degraded. This was exactly the same when listening to both sources through headphones. Anyway, I sent it to be repaired and have just got it back. Annoyingly, the exact same problem still exists. The repair agents have replaced the pcb and a speaker input and it was tested by the retailer before sending.
I've just called the retailer and am waiting to hear back.
Is there anything that may have caused this to happen from the mains socket or whatever? It seems very odd for the exact same problem to occur.
which amp is it? does it have L/R fuses?
If one channel is louder than the other, swap the speaker connections. If the fault moves to the other speaker the problem is in the amp. If the amp isn't faulty then it does sound like both the sources are, unlikely though it sounds for both to fail at once in different ways.
I was going to replace the CD player anyway at some point.
@robgilmo the amp is a Yamaha AS501 and it's just over a year old, and probably didn't need repairing at all. Talking to the shop yesterday, they mentioned the repair agents had replaced the pcb as a precaution. Luckily it is still under warranty.
You could go to https://www.vinylengine.com/turntable_forum/ and enquire about rewiring a Rega arm, or google it, there is lots of info regarding arm rewires,
What you could try is wiggling the wire at the phono plug (gently) to see if the channel comes alive, this will indicate the cable fault at the plug, which is quite common.
@boogieman I'll try but everyone seems to just stream. I was going o buy a new CD player at some point anyway, so will see. I am pretty confident now that the amp isn't the fault tbh. It's a pita really!
