I've built a couple of great boards from Tagboard FX website. I keep meaning to do more.
My biggest hate is getting it all in the enclosure. I tried using double sided sticky pads to attach the board to the back of the pots and using thick tinned copper wire on the pot tags so that the board is held by those. I wouldn't say either approach is perfect.
The small boards you can get to mount 3pdt switches on are great. Even better are the ones with opto-coupler switching or micro-controller relay switching. See here: http://1776effects.com/product-category/pcbs/
IMO, the best mounting method is if the PCB is pot mounted. Made even easier if you use the Tayda Alpha pots as they have little plastic covers on them. If the PCB is built with this in mind, you're golden. I personally use some copper solid core cable to make legs on the pots and mount via those wherever possible. This makes things very solid and secure.
When this is not an option you're left with improvised mountings (especially if you're building on vero or perf). Generally speaking you're using some scotch tape and wire. It's shit, but it's really the only way unless you want to create the special sort of ugly mess that the likes of Devi Ever does and just wrap it in electrical tape and leave it floating in there.
As someone mentioned above, the stomp boards are a great way of making a tidy build. I personally do not like 3PDT stomps, but there are also, as mentioned some nice opto-switching boards out there from the likes of 1776 and Grind, and some less neat but still effective relay ones from the likes of TH Custom. Getting all that done and just leaving 4 wires to the effect makes a huge difference and I highly recommend it.
FWIW there are some tutorials on my site for finishing and some more complex stuff (but it might give you ideas). I'd also suggest going on the Madbean forums. It's a good noob-friendly place to start.
Also +1 on madbean forums super noob friendly place I've spent the last year data mining that forum via the search function.
I'm sure Juan will answer for himself but his look like single core perhaps 1/0.6. It is good for staying in shape after you bend it, but can snap if you nick it with the cutters or bend it about too much.
There is also 16/0.2 or 7/0.2 which are multiple strands of wire in the same insulating sheath (16 strands of 0.2 wire for example). Sometimes 16/0.2 can be a bit big to fit into PCB holes by the time you tin it.
I tend to use a mix of the above. I use solid for shorter or straight runs and the more flexible stranded stuff for longer or looping reaches.
