I know what you mean. In isolation it can sound more in tune than my regular Blade guitar. But as you've said, it can be strange hearing it especially in a mix. I've had another band member screaming 'Tune that F*&^%$£ Guitar!' at me, only to find it correct on the tuner.
I took it to Jaden Rose who gave it a great set-up and checked the nut and intonation. It's just a different set of compromises than we are used to. I have considered getting a regular nut put on there.
The other way is to actually compensate the nut which can vary from a reduced nut to first fret distance (ala PRS), a slight angle on the nut, or an individual offset for each string. Its kinda fixed in place but can be balanced with the bridge compensation. lots of info on that here, but things like the earvana nut are as god a place to start as any.
The buzz feiten system basically uses a combination of those things along with bridge compensation offsets
Finally you can actually compensate the frets themselves, which takes you down the curvy fret/true temperament system. That system is about as close as it gets for standard set-ups
or you can just accept the standard guitar with its tuning imperfections. not a good enough answer for some, but most are okay with it.
Instagram
Many guitars have a re-sale value. Some you'll never want to sell.
Stockist of: Earvana & Graphtech nuts, Faber Tonepros & Gotoh hardware, Fatcat bridges. Highwood Saddles.
Expert guitar repairs and upgrades - fretwork our speciality! www.felineguitars.com. Facebook too!
