Pattern to try in Gmaj.. now with a audio example
BarneyBarney Frets: 614
edited August 2013 in Technique
..............................................................................................................................................................3.........7
...........................................................................................................................3..........................5...............
....................................................................................4...........................5.................5...........7.........................
........................................4................................5................5.........7......................................................................
..........................5.......................5..........7...................................................................................................................
.....3.........7....................................................................................................................................................................
picking pattern is... down, hammer, down, finger, down ..ect......its good to try through each of the modes...
audio
http://soundcloud.com/user5011288/pattern
0reaction image LOL 1reaction image Wow! 4reaction image Wisdom
  • bigjonbigjon Frets: 680
    That's a goodie! :-)
  • BarneyBarney Frets: 614
    Hope it came out OK....just looked on my phone and thers lines everywhere ...lol...its like 2.. 3 string guitars ...:)
    Ahh just put the phone sideways a.d its OK :)
    just done a recording of this pattern so you can here what it goes like.....or see iff you like it...its slow then a bit faster,,:)
  • CatthanCatthan Frets: 355
    That's excellent,
    I've a bit a problem using ascending phrases and that's a nice one to work on.
    Thanks
  • Nice! Great to have the audio clip as a quick preview.
    Catthan said:
    That's excellent,
    Thanks
    its a handy way to do arps that way as well ....just repeat the same pattern with the right hand on the first group of 3 strings then the last group of 3 ...and alter the left hand fingering to accomodate that... :)
  • ClarkyClarky Frets: 3261
    like that a lot.... very cool...
    very nicely done too...
  • DiscoStuDiscoStu Frets: 5372
    Props from Clarky!
    That deserves a wow.
    I might attempt failing this tomorrow...
  • vizviz Frets: 10643
    Nice! Nice reverby sound too.
    DiscoStu said:
    Props from Clarky!
    I didn't actually know it was possible to see who sends the props...
    DiscoStu;17284" said:
    Props from Clarky!That deserves a wow.
    Haha....you won't fail it you will nail it...just practice it 4 notes at a time doing it really slow to start with... :)
    @Barney - I was noodling with that lick...
    something that sounds quite cool is if you imagine it at the end of the song..
    play it with ritartando and for the last note, rather than hammer 3 to 7 on the 1st string
    slide from 3 up and then fret the D on the 10th..
    sounds a little sweeter if the slide don't make it all the way too..
    so you head from the 3rd upwards and break off somewhere in the 6th to 8th fret area and then hit the D
    sounds really quite pretty..
    @clarky yeah I agree just tried that now ..it would make a nice tight ending .. :) I think another thing worth messing with is missing strings ...so start the run on. The E string as normal but the miss the A string and jump to The D string....then back to A string then to G ...iff you get the just of that...lol.. Just same pattern but skipping strings....
    While on that subject....something that I sometmes do before changing strings or on a old guitar is take maybe the. B and D string off....or it could be any or just one...doing different strings at different times.....then I just noodle away for a couple of days ...it makes you play in a different way ..makes everything more intervalic...cos you dont/cant use the regular runs......when you put the strings back on this still sticks because it has become part of your playing...something really worth triying regardless of level of players...it makes you think in a different way.. :)
    interesting.. I'll have to give that a go...
    just done the above example with string skipping i case you woukd like to here it... :)
    same picking pattern and notes ....just skipping strings ...done one slow and one a bit faster
    http://soundcloud.com/user5011288/string-20skip-20in-20g
    haa... very nice...
    quite a bit more difficult too
    Clarky said:
    haa... very nice...
    aye its a bit more awkward but worth it cos it can be moved around a lot using the same r/hand picking pattern.. :)
  • great stuff Barney, thanks for this !!
