Hi,
I just got a DD-20. I had been using a DD-7 with an EV5 expression pedal but it was taking up a lot of space on my board and I was basically just using a lower mix / 3 repeats of a 500ms delay or a higher mix with multiple repeats for some solos.
Trouble is the DD-20 doesn't sound nearly as clear/crisp on the repeats when using gain (pedal in front of the amp, or the amp's drive channel).
I run my delays in the loop and I've tried changing the level of the pedal from -20dB to +4dB as is suggested.
Is this just a characteristic of the pedal? It's not distorted...it's just not as clear...
I should say I also got the DD-20 as I like the ease of being able to programme in a delay like 197ms for set pieces like Nuno's Flight of the Wounded Bumblee....feel free to throw alternatives at me.....although I bet what gets mentioned is £400+!
Thanks,
Andy
Quite a few demos on YT
http://www.thefretboard.co.uk/discussion/97526/fs-providence-chrono-delay-dly-4#latest
You don't mention what amp you're using, or how much gain. If you're going from a very clean sound to one with a lot of distortion (your avatar looks like a flyer for a metal gig, so I suspect you are) you might just have to dial in different presets for the dirty sounds- probably with fewer repeats, and perhaps with the effects level turned down. Big, lush delays with lots of repeats sound great with cleaner tones, but it all becomes a bit too much with distortion too.
Hi, I'm using the "Standard" mode at the 12 o' clock position which is supposed to be straight digital delay I believe.
I play in a prog rock/metal band....but also in a reggae band so aware of the clean/high gain issue....generally I find putting the delay in the loop deals with the difference in effect intensity with/without gain.
This is a straight comparison of a DD-7 with a DD-20 used in exactly the same way. That said, I do need to give the thing more of a chance....it was my first impression....
Btw I use an Engl Ironball that does everything from warm clean to absolute filth! The Bright Onion pedal is the boost/channel selector and on the clean selection it has a loop function. That is fed into the Wobo looper (!) such that I can preselect either the EQ to scoop the clean for a more Fender-like sound......or the Plexitone for a more.....well Plexi-like gain....and of course both or neither....I find it to be a very flexible set up
It may be that the DD-20 just isn't for you- there isn't a huge range of control over how it sounds in any mode. I would definitely stick with it for a bit though.
FWIW, the Boss DD-500 has a hugely powerful EQ that would almost certainly allow you to get a delay sound that works with all your tones. It's also twice the price of the DD-20 used, considerably more complicated and less like the Boss stompbox delays.
I stuck with the 20, and recently tried the 3 again. Yes I felt the difference was still there, only this time the 3 sounded thin in comparison, I much prefer the 20. Sold the 3.
The 20 is very user friendly, lots of easy to access options, without paralysis
One thing you might try is putting a volume pedal in the fx loop before the 20, you can drop the level going into the 20 with then turn up the power amp to compensate. Or a pedal with a vol control, or one of those volume boxes (basically a vol pot in a box).
It could be the lack of clarity is distortion cos the signal is too strong for the 20 and overloading it so it's clipping. I had that with the 3 and the 7 and even the 20 on the +4 dbu setting. Volume box sorted that
Tap tempo and memories.
Looper too.
Im selling it.
For money.
Mostly.
