What is your existing PSU and what pedals did it kill?
killed a rare hand painted Pigtronix Tremvelope, and a Strymon El Capistan.
Both beyond repair.
Gutted.
M
The basic Generator is just for 9V with loads of power on tap. It's small plus it has an intelligent power sensor that detects other non-UK voltages so you can use it abroad without any issues.
Worth a look but big footprint.......less spendy than others. I got mine here and it works well.
There's things I've had, there's things I wanna have"
How did that happen?
I've been very happy with my ISO 5. It does 9v, 12v and 18v, although possibly not enough outputs. I daisy chain pedals that are happy to work together so effectively I power about 12 pedals including 1 hungry digital one. Dirt pedals I just put on a daisy chain. What I've found is most collections of pedals don't need complete isolation, just enough to keep the dirty ones away from the others.
What you need will depend on what pedals you have. If you have lots of high current digital pedals you will need to spend more than if you have 10 drive pedals and a handful of digital ones.
While it's ok to daisy chain some pedals together I would definitely try and run digital pedals off of isolated outputs. You can sometimes get weird things happening with tuners as well. I'd try and keep a tuner pedal on its own isolated output as well.
Never trusted the power supplies since.
I'm experimenting a lot with pedals at the moment, so run between 8 and 15 pedals (size limit). Just added two new ones (Moore Rat clone to goose my Reverb Tank, and Nocturne Atomic Brain - Pre Amp). So, back up to 15 on the board. Most power requirement is for various delay effects, and MXR M300 reverb pedal (i use tank and pedal for different reverb effects).
I usually use two drives for stacking. One low gain, one even lower, boosts, Sonic Stomp clone, wah, several fuzz units.......also added a Symbal Pre Driver... will probably settle on 8-10 pedals.
Trying out compressors at the moment, but they just bewilder me. But, I don't do gain much, and hate country music, so probably not meant for me. Ho hum...
My core tone is low powered pickups into 5E3 on edge of breakup, but working hard.
