Speakers could be T1281 or T1886. The T1886 is more of a bass speaker with the looser spider support and will sound less compressed and more 'open', but will still sound good so long as they are in good condition. The T1281 is a classic (used by Hendrix etc) and is one of the most sought after Celestion speaker models.
If they're asking a lot of money always check them over in person if possible. Never assume speakers that old are just going to be perfect and worthy of a high asking price, most of them are not.
The 55hz bass cones are the one's for guitar, the T1281's are the classics. Always been confusing calling them bass cones, imo the 30w spec 55hz's are best, likewise the 75hz (lead cone) T1221 are best for the G12M greenback.
As Bygone Tones says I would check the performance of each speakers at volume if you can.
I have had a checkerboard cab which had G12H-30 55Hz Blackbacks, it was a '76 if I remember rightly. Of course it's impossible to be absolutely certain the speakers were original, but they were a date-matched set and the soldering was perfect, both of which are very rare if speakers have ever been changed.
It's only because they were used in the bass spec 4x12"s… when bass players still used such things!
Also agreed - the ultimate stack is a straight cab with 55Hz 30s and an angle with 75Hz 25s… and an aircraft hangar to play it in .
Around 1975 or 1976 the UK Marshall cabs got the black grill, and the US cabs got the small check grill until about 1980. There are some of those small check cabs knocking about in the UK.
http://i4.photobucket.com/albums/y142/riffpowers/8FF542E4-4134-4CA1-B38E-85CA2E5BACF1_zpsgcomlfyv.jpg
http://i4.photobucket.com/albums/y142/riffpowers/55C7FB8B-1FA4-409E-A2B4-851204B1B703_zpspb5xxcaz.jpg
http://i4.photobucket.com/albums/y142/riffpowers/E57F9A48-60A2-407F-AC3F-41458E48C4C4_zpsqj5fvlfz.jpg
http://i4.photobucket.com/albums/y142/riffpowers/C088DE44-D8C7-42F0-B854-15FAF955DEB2_zps071bsb1q.jpg
http://i4.photobucket.com/albums/y142/riffpowers/4F09416B-59CF-4A64-ABF6-BFEECCE9F444_zpszkpynko8.jpg
http://i4.photobucket.com/albums/y142/riffpowers/22DD2F2B-436A-47AC-AEE8-67C523ECE813_zpskybyt1e9.jpg
I would check those 3 remaining speakers for cone rub etc. if one has been replaced.
Have to say the owners got an unusual way of operating his foot pedals! unless he plays lying down!!!
The cab itself only has player value because it has been messed about with, so maybe around 80 for it empty? The heritage speaker should be fine unless it has been mis-treated somehow, so maybe 60 to 70 for that one? Its the blackbacks you need to be careful about.
Its a bad photo but looks like a 1984 model cab to me, which means those are more likely to be T1886's. Personally I get less excited about those than the T1281's, and find them to be more problematic too. Celestions with the bass spider support tend to be more prone to coil rubbing.
Ideally you need to remove the wiring and isolate each speaker individually to test them properly.
I've played it, but I don;t know enough about speakers to know about cone rub.
