when in doing that kind of thing I run the Helix in stereo but I have done the same using a Kingsley Jester at the end of the chain and using the boost section to control it
if it's lunar skynard though the crunch channel on the dsl s is decent and cleans up with volume
forget trying to use them as two channel amps
if you Eq the clean to sound nice the drive is awful and vice versa
Eqd Speaker Cranker clone
Its not going to be be as spanky or Fender like as you are used too, but as long as you don't hammer the front end too much with input volume and scoop the mids slightly I reckon it will do.
Marshall cleans are pretty underrated.
but get there early and nab the 800!!!
(Speaking as a TSL owner .)
You'll get a "better" - ie more Fender-like - clean from the TSL than any of the others.
If there are two TSLs, set the second one up exactly the same as the first before you start, it will save time if you need to swap mid-set .
If you're a Skynyrd tribute band I assume you have three guitarists, so each of you can do the same, with one of the others using the DSLs and the third with the 800s.
• Youtube - https://www.youtube.com/@Goldeneraguitars
I would go for the 800, use the low input and push the gain up high, on 10 if you have single coils. It will be nice and warm and punchy and will take drive pedals like a champ
On re-reading the spec sheet, I noticed this:
"Guitarists may also use their own amp heads but please be aware of the short changeover time available to you."
So, I have a Traynor YRM-1 (head version of the YRM-1SC 4x10 combo) which I think I'll take down and play through a 4x12 cab.
Regardless of which amp I use, I built a board which should get me a reasonable sound into any half-decent amp:
Signal path: G70 -> wah -> Cali76 -> Tumnus -> Tonebone -> Simble -> Juansolo Tubescreamer -> 30ms -> ABY
The ABY is for when I use either two amps (clean/dirty) or my Bandmaster head which has a tweed channel and a Blackface channel.
Looking forward to the gig!
R.
Don't get me wrong, I don't think it's brilliant - I didn't exactly choose to own mine on purpose, and I have modded it a bit - but it isn't *that* bad. (When it's working… ) It's slightly more Fendery than the DSL clean too, which is why I would recommend it as the first choice if you only have those three options.
If the 800 is a 2203/4 that would be much better though.
I took my YRM-1 head and plugged into a 4x12.
Got a great sound, probably due to lack of iPhone.
R.
