Ibanez Sure-Grip knobs
Does anybody if there are any UK stockists of these or similar?  I've got them on my Ibanez George Benson and they're way more functional than the unresponsive top-hats I've got on my Les Paul.
Trading feedback info here
My band, Red For Dissent
  • sweepysweepy Frets: 4183
    I got mine from eBay but you need to check the spline/shaft size as the Japanese ones will not fit Gibson. uS pots
  • imalrightjackimalrightjack Frets: 3745
    edited March 2017
    Interesting.  Good shout, @sweepy.  I switched them over earlier and they seemed to fit okay...maybe a bit of a tight fit.  Better check!
    @TheGuitarWeasel - can you let me know what size splines/shafts are on the new pots you're pulling together for me?  If you stock anything like these above, send me an invoice
  • TonyRTonyR Frets: 908
    If you're struggling could you achieve the same thing with the standard top hats and some Lego tyres?
    We are all Chameleons...
  • FelineGuitarsFelineGuitars Frets: 11593
    edited March 2017 tFB Trader
    The Ibanez ones are Jap thread so aren't a good fit for CTS pots.  Ash's pots will be CTS.
    Jap pots like Alpha have fewer splines but are deeper whilst the CTS and other USA made ones have more splines with less depth.
    Be careful trying to put them on CTS post as they will often crack as you force them on . The plastic splines are deeper than the ones on CTS pots so you can improve your chances with making them fit by carefully trimming back the plastic with a reamer or a carefully chosen drill bit that will just reduce the size of the splines. It will still be tricky but it will improve your chances of it working out
  • axisusaxisus Frets: 28336
    Yerk! They look .... Weird.
  • Trading feedback info here
    These are the Suregrip 2 with the rubber on the top of the knob
    The older lates 70s ones had a rubber insert (I preferred the look) but over a long time the rubber grip bands would get slack or perish and come off
    I see they are now up to suregrip 3
    Thomann sell them
  • lasermonkeylasermonkey Frets: 1940
    I sold the Suregrip knobs from my long-gone Ibby SB70 on eBay a while back and got forty quid for them!
    My wife asked me to stop singing Wonderwall.
    I said maybe.....
  • Jack_Jack_ Frets: 3175
    Aesthetics are more important than functionality.
  • OilCityPickupsOilCityPickups Frets: 10364
    All my pots are CTS, so what @FelineGuitars says is correct re them not taking Japanese knobs well (fnar fnar) there's a Trump joke floating around there somewhere ...
    Ok, I'll give you that one. Looks v cool.
  • I use to have a Baker strat that had a pull pot on the last tone knob. It was a pig to pull, the solution was a rubber band!
  • AlnicoAlnico Frets: 4616
    Does the same go for EMG pots?
    Would the Sure Grip 3 knobs fit on EMG solderless pots ok or are they likely to be the same as CTS?
    edited July 2017
    Well I found the answer,..........I *think*.
    The Sure Grip III looks like it's an 18 spline knob, I found a photo of one and counted them.
    I just counted the splines on my EMG pots and there's 9 either side of the split shaft, making 18.
    EDIT: I just counted the splines on the volume pot that came installed in my Ibanez Iron Label and that's 18 splines as well. Hold the EMG pot beside it and they look identical.....
    http://i.imgur.com/xh5Enhz.jpg
    2 Sure Grip III's in Black ordered from Thoman this morning.
    EMG neck pickup cable ordered from Selectron on Friday, arriving soon.
    EMG 85 bought to replace 81 in Bridge position.
    EMG 81 being moved from Bridge to Neck position. ('60' now spare. Body Mounted)
    EMG 3 way switch bought, second battery to mod to 18v power, wiring and pots all ready to replace Ibanez wiring harness.
    EMG Tone control replacing Ibanez/Dimarzio Kill Switch.
    Photo's when it's all done.
    Link to the item, @Alnico ?
    Sure, no problem.....
    Click HERE
    It's all going into THIS.
    I got it a few weeks ago, they're discontinued now.
    Thank you, @Alnico ;
