If you need more visibility the Korg Pitchblack Pro looks good, though on paper it won't quite be as accurate as the Peterson. Whether you can hear that will be personal, I can't hear +- 1 cent as being out but the Peterson is +-0.1 cents so is still better on paper.
I considered the Korg but then realised I'm never far enough away from my Axe FX that I can't see the screen.
I don't know the spec on the Axe FX tuner but it seems pretty accurate to me
To be honest with you, it's a gas thing, having a cool looking rack tuner above the Axe will be good, save me going in and out of modes...but you're right, I should at least try the Axe tuner first! :-)
Also, if it's a gas thing, GSP1101 has a decent tuner
I have the korg pitchblack pro rack mount and well happy with it. Very clear large display and always on so easy to tweak. Only use it at home so don't know how it would stand the test of travel/gigging.
