http://www.thefretboard.co.uk/discussion/89942/caspercaster#latest
The JD wiring out of phase sound is supposed to emulate a Strat, and is often referred to as HOoP (Half Out of Phase) - it isn't really very Stratty, but is better than the regular out of phase sound IMO, and only requires one jumper on the back of the S1 switch to be replaced with a capacitor, so a very quick and simple change to make.
It's also worth looking at the mod to reduce noise when the bridge pickup alone is selected (perhaps the Baja's real Achilles heal). Fender wire the 4-way switch with the neck pickup +ve connected all the time, and lift the earth to the neck pickup when required (so it isn't active when the bridge pickup alone is selected). Unfortunately the neck pickup therefore acts like an aerial (-ve end left floating) and introduces noise when the bridge pickup alone is selected - dumb as most people buy a Tele for the bridge pickup sound! It's easy to remedy this by tying both ends of the neck pickup together (so both ends of the neck pickup will be at the same potential) when the bridge pickup alone is selected - just one short jumper added to existing wiring on the 4-way switch if my memory serves me correctly.
Of course, if the S1 switch bothers you it can easily be removed to remove the phase reverse function. And although it is a 4pole changeover switch the phase reverse function only requires a 2pole switch (DPDT) like a regular push/ pull or push/ push pot, or indeed a toggle switch.
