Short version of events: I want a 2-channel amp with series fx loop and would dearly like an Egnater Renegade 65 but they're not made anymore and are horribly unreliable (so won't touch one second-hand). I thought the Fender Super Sonic 22 would be a good alternative but, much as they sound great, they have a reputation for unreliability and the one I just got came with faults. Meh. Both of these are very close to what I want. I want clean that I can use as it is - and overdrive into a light break-up. I also want a heavier channel that I can push further, into fat saturated leads.
So...the Friedman Runt and Victory V30 have two channels. Apparently nice clean pedal platforms and have good overdrive channels. I don't think a single-channel amp gives me enough to work with for what I want.
I couldn't get away with the Mesa Mark V:25. Too difficult for me to dial in.
Head or combo, not fussed.
Opinions welcome.
JM build | Pedalboard plans
My band, Red For Dissent
Is size an issue too? The victory wins on form factor you simply won't believe how loud it is for such a small enclosure, it's insane! If you get the 50w runt it's a sizeable head.
Both sound great anyway.
I instantly was reminded of my old 2555sl when I first fired up the runt in guitarguitar camden. I also did an a/b with a victory rd1, victory v30 and runt 20 at andertons and the runt was the one I liked the most running through a victory 1x12 like I have at home. The reason for this is certainly the presence control on the runt which the v30 doesn't have.
Did you a/b with the Runt 50?
PA Hire and Event Management
For example a great tone could be had on the "burn" setting with the eq at zero on treble and bass and mids at 9 o'clock, sounds crazy, but it gave a great edge of breakup old marshall sound with the gain set low.
I only tried the Recto at a shop in combo form, it was great but sounded similar to the express and not worth the price jump on the 2nd hand market IMO.
It was great , I want one !
http://thefretboard.co.uk/discussion/96312/fs-ft-price-drop-friedman-runt-50-combo-1200#latest
Hotrod and boost are foot switchable.
